* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Add support for Motorola MPC8266ADS board
* Patch by Kyle Harris, 19 Feb 2003:
patches for the Intel lubbock board:
memsetup.S - general cleanup (based on Robert's csb226 code)
flash.c - overhaul, actually works now
lubbock.c - fix init funcs to return proper value
* Patch by Kenneth Johansson, 26 Feb 2003:
- Fixed off by one in RFTA calculation.
- No need to abort when LDF is lower than we can program it's only
minimum timing so clamp it to what we can do.
- Takes function pointer to function for reading the spd_nvram. Usefull
for faking data or hardcode a module without the nvram.
- fix other user for above change
- fix some comments.
* Patches by Brian Waite, 26 Feb 2003:
- fix port for evb64260 board
- fix PCI for evb64260 board
- fix PCI scan
* Patch by Reinhard Meyer, 1 Mar 2003:
Add support for EMK TOP860 Module
* Patch by Yuli Barcohen, 02 Mar 2003:
Add SPD EEPROM support for MPC8260ADS board
