path: root/board/evb4510
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-07-11* Patch by George G. Davis, 06 Jul 2004:wdenk
- update mach-types.h to latest arm.linux.org.uk master list - Set correct OMAP1610 bi_arch_number for build target * Patch by Curt Brune, 06 Jul 2004: evb4510: add support for timer interrupt; cleanup
2004-07-01* Code cleanup (ARM mostly)wdenk
* Patch by Curt Brune, 17 May 2004: - Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC) - Add support for ESPD-Inc. EVB4510 Board
