path: root/board/eukrea
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-04cpuat91: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Eric Bénard <eric@eukrea.com>
2011-06-21cpuat91: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-06-21cpu9260/9G20: fix board supportEric Benard
2011-04-27cpuat91: fix board supportEric Benard
- fix board support following relocation changes - switch to boards.cfg - disable i2c to keep size under 128kiB (1 sector) Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-04-27cpu9260: update board supportEric Benard
- update to new relocation code - switch to boards.cfg - get rid of LEGACY (still a little hack in .h to compile) - add nand boot configuration - boot tested for the following configurations : 9260 (64MB RAM & nor boot) 9260_nand (64MB RAM & nand boot) 9G20_128M (128MB RAM & nor boot) 9G20_nand_128M (128MB RAM & nand boot) (nor boot is using lowlevel init) Signed-off-by: Eric Bénard <eric@eukrea.com>
2010-08-20cpuat91: convert to new at91 soc architectureEric Bénard
convert the board to the new soc architecture update default config i2c upgrade taken from eb_cpux9k2.h & board/BuS/eb_cpux9k2/cpux9k2.c Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-18AT91 CPU9260 Fix machine ID when using a CPU9G20.Eric Benard
Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13Add support for Eukrea CPU9260/CPU9G20 SBCTom Rix
these boards are built around Atmel's AT91SAM9260/9G20 and have up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND and include a 10/100 Ethernet PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13Add support for Eukrea CPUAT91 SBCTom Rix
CPUAT91 is built around Atmel's AT91RM9200 and has up to 16MB of NOR flash, up to 128MB of SDRAM, and includes a Micrel KS8721 PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
