path: root/board/espt
2011-02-02sh: Remove config.mk for espt boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-08-30sh: Update lowlevel_init.S of espt-gigaNobuhiro Iwamatsu
Fix data size. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2009-10-30sh: Update lowlevel_init.S of espt-gigaNobuhiro Iwamatsu
There was the point that did not use write macro. Change to write macro. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-11sh: Add support ESPT-GIGA boradNobuhiro Iwamatsu
ESPT-Giga is SH7763-based reference board. Board support is relatively sparse, presently supporting serial, gigabit ethernet, USB host, and MTD. More information (in Japanese) available at: http://www.cente.jp/product/cente_hard/ESPT-Giga.html Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
