path: root/board/esg
2012-09-01fsl_esdhc: Remove cache snooping for i.MXBenoît Thébaudeau
The cache snooping feature of Freescale's eSDHC IP is not available on i.MX, so disable it globally for this architecture. This avoids setting no_snoop for all i.MX boards, and it prevents setting a reserved bit of a reserved register if fsl_esdhc_mmc_init() is used on i.MX, like in arch/arm/cpu/armv7/imx-common/cpu.c/cpu_mmc_init(). Since no_snoop was only used on i.MX, get rid of it BTW. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com>
2012-07-07ima3-mx53: Remove unused SOBJSFabio Estevam
There is no .S file in this directory, so just remove SOBJS. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-15MX53: Add support to ESG ima3 boardStefano Babic
The ESG ima3-mx53 board is based on the Freescale i.MX53 SOC. It boots from NOR (128 MB) and supports Ethernet (FEC), SATA. Signed-off-by: Stefano Babic <sbabic@denx.de>
