Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This change lays the groundwork for the BOOTFLAG_* flags being removed.
This change has the small affect of delaying 100ms on PCI initialization
after a warm boot as opposed to the optimal 1ms on some boards.
included the mpc8308_p1m board.
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
This patch starts a bit PPC4xx header cleanup. First patch mostly
touches PPC440 files. A later patch will touch the PPC405 files as well.
This cleanup is done by creating header files for all SoC versions and
moving the SoC specific defines into these special headers. This way the
common header ppc405.h and ppc440.h can be cleaned up finally.
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By
moving these optional variables and defines into the common code, board
specific code is minimized. Currently only the following board use
this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not
updating the bank number variable at all. So this patch removes the
definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
There was an redesign, so USB is available now.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
* convert meesc board to use c stucture SoC access
* change gpio access to at91_gpio syntax
* moved CONFIG_SYS_HZ below board and cpu defines (purely cosmetic)
Update image size and default environment
after addition of new environment handling.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Update image size after addition of new environment handling.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Acked-by: Detlev Zundel <dzu@denx.de>
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code
dedicated to defining and manipulating the LBC registers. Merge
this into a single spot.
To do this, we have to decide on a common name for the data structure
that holds the lbc registers - it will now be known as fsl_lbc_t, and we
adopt a common name for the immap layouts that include the lbc - this was
previously known as either im_lbc or lbus; use the former.
In addition, create accessors for the BR/OR regs that use in/out_be32
and use those instead of the mismash of access methods currently in play.
I have done a successful ppc build all and tested a board or two from
each processor family.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Due to some overlapping sections it's time to update TEXT_BASE
for this board.
Add ECC support for DDR RAM for MV64360 on esd CPCI-CPU/750 board.
This patch also adds the "pldver" command to display the CPLD
revision.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Cc: Peter Tyser <ptyser@xes-inc.com>
This patch adds new macros, with frequently used combinations of the
4xx TLB access control and storage attibutes. Additionally the 4xx init.S
files are updated to make use of these new macros. Resulting in easier
to read TLB definitions.
Additionally some init.S files are updated to use the mmu header for the
TLB defines, instead of defining their own macros.
The appropriate include/asm-$ARCH directory should already by symlinked
to include/asm so using the whole "asm-$ARCH" path is unnecessary.
This change should also allow us to move the include/asm-$ARCH
directories into their appropriate lib/$ARCH/ directories.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
We do not support a processor that never reached a real customer.
Signed-off-by: Detlev Zundel <dzu@denx.de>
* convert otc570 board to use c stucture SoC access
Configuration defines should be preceeded with CONFIG_SYS_. Renamed
some at91 specific defines to conform to this naming convention:
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME
AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
This patch adds support for esd gmbh OTC570 board.
The OTC570 is based on an Atmel AT91SAM9263 SoC.
The init_coupler() function from board/esd/plu405/plu405.c
got lost somehow! This patch readds it.
Normally the processor clock has a divisor of 2.
In some cases this this needs to be set to 4.
Check the user has set environment mdiv to 4 to change the divisor.
Remove PCI reset, if there is a monarch PMC module.
convert clrbits_be32 + setbits_be32 to clrsetbits_be32, use out_be32 to set gcr.
The caddy2 is a variant of the already supported vme8349. So we just
add the differences to this board port. To better support those two
boards we switched from fixed SDRAM configuration to usage of
spd_sdram(). This is done by providing a board specific SPD EEPROM
routine with different values for both boards.
changed to use mkconfig -t option instead, plus misc codingstyle fixes.
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus
repeated in every file using it. This patch moves the prototypes to
common.h and removes all prototypes distributed anywhere else.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
u-boot updates, before starting Linux, the memory node in the
DTS. As this is a "standard" feature, move this functionality
to the cpu.c file for mpc5xxx and mpc512x processors.
This patch introduces a weak default function for post_hotkey_pressed(),
returning 0, for boards without hotkey support. The long-running tests
won't be started on those boards. This default function was implemented
in many board directories. By implementing this weak default we can
remove all those duplicate versions.
Boards with hotkey support, can override this weak default function
by defining one in their board specific code.
drivers/rtc/ftrtc010.c
The autoupdate feature is not used on PLU405 boards.
So remove it.
This is not the sequoia board.
This patch removes the duplicted implementations of the pci_master_init()
function by introducing a weak default function for it. It can be
overridden by a board specific version.
This patch removes the duplicted implementations of the pci_pre_init()
function by introducing a weak default function for it. This weak default
has a different implementation for some PPC variants. It can be
This patch removes the duplicted implementations of the pci_target_init()
has a different implementation for 440EP(x)/GR(x) PPC's. It can be
overridden by a board specific version (e.g. PMC440, korat).
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch fixes an ugly behavior of the IL712 magnetic coupler
as used on VOM405. These parts will remember their last state
over a power cycle which might cause unwanted behavior.
This patch fixes an ugly behavior of the IL712 magnetic couplers
as used on PLU405. These parts will remember their last state
This patch introduces a weak default function for is_pci_host(),
returning 1. This is the default behaviour, since most boards only
implement PCI host functionality. This weak default can be overridden
by a board specific version if needed.
All these linker scripts can be removed since the new common ppc4xx
linker script should be able to handle all of those boards.
Please test and report problems. Thanks.
These boards have special linker scripts right now. We can't use the
common 4xx linker script here. So overrride the linker script (LDSCRIPT)
in board/*/config.mk and choose the board specific version.
These files were autogenerated by EPSON configuration tools.
This patch replaces the autogenerated file headers by the GPL
license notice.
This change is done with the explicit permission
of Epson Research & Development / IC Software Development.
