path: root/board/esd
2005-10-08Fix gzip bmp support (test if malloc fails, warning when truncated).Stefan Roese
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board. Patch by Stefan Roese, 08 Oct 2005
2005-09-30Fix problem with SM501 init on HH405 board.Stefan Roese
Patch by Stefan Roese, 30 Sep 2005
2005-09-25Fix VOH405 SupportWolfgang Denk
Patch by Matthias Fuchs, 25 Sep 2005
2005-09-25Add support for AMD's Pb1x00 eval board;Wolfgang Denk
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005
2005-09-24* Fix PHY address argument passing with mii info commandWolfgang Denk
Patch by Andrew Dyer, 28 Dec 2004 * Cleanup: fix broken builds
2005-09-23More cleanup: get rid or redundand #definesWolfgang Denk
2005-09-22esd CPCI2DP board addedStefan Roese
Patch by Matthias Fuchs, 22 Sep 2005
2005-09-22esd PMC405 board updatedStefan Roese
2005-09-22Add SM501 support to HH405 board.Stefan Roese
Add support for gzip compressed bmp's (CONFIG_VIDEO_BMP_GZIP). Add support for eeprom write-enable (CFG_EEPROM_WREN). Patch by Stefan Roese, 22 Sep 2005
2005-08-23Merge with testing-4xx_enet (Create generic 4xx Ethernet code)Wolfgang Denk
2005-08-22Add esd cpci5200 and pf5200 boardsStefan Roese
Patch by Reinhard Arlt, 22 Aug 2005
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-08-12esd PCI405 board updatedStefan Roese
Patch by Matthias Fuchs, 28 Jul 2005
2005-08-12esd WUH405 and DU405 board updatedStefan Roese
Patch by Matthias Fuchs, 27 Jul 2005
2005-04-20* Patch by Matthias Fuchs, 18 Apr 2005:stroese
Make PCI target address spaces on PMC405 and CPCI405 boards configurable via environment variables
2005-04-13Update for esd apc405stroese
2005-03-17Update for esd auto_update and hh405 boardstroese
2005-03-16Update for esd auto_update and hh405 boardstroese
2005-03-14Update for esd voh405 fpga imagestroese
2005-03-01Update for esd boards dp405 and hub405stroese
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-12-17One more code cleanup.stroese
2004-12-16Code cleanup.wdenk
2004-12-16PCI405 board updatestroese
2004-12-16AR405 board updatestroese
2004-12-16esd common updatestroese
2004-12-16VOH405 board updatestroese
2004-12-16PMC405 board updatestroese
2004-12-16PLU405 board updatestroese
2004-12-16OCRTC board updatestroese
2004-12-16HUB405 board updatestroese
2004-12-16DU405 board updatestroese
2004-12-16DP405 board updatestroese
2004-12-16CPCIISER4 board updatestroese
2004-12-16CPCI440 board updatestroese
2004-12-16CANBT board updatestroese
2004-12-16ASH405 board updatestroese
2004-12-16ADCIOP board updatestroese
2004-12-16CPCI405 board updatestroese
2004-12-16WUH405 board support addedstroese
2004-12-16VOM405 board support addedstroese
2004-12-16TASREG board support addedstroese
2004-12-16HH405 board support addedstroese
2004-12-16CPCI750 board support addedstroese
2004-12-16APC405 board support addedstroese
