path: root/board/esd
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-07-06at91: Add esd gmbh MEESC board supportDaniel Gorsulowski
This patch adds support for esd gmbh MEESC board. The MEESC is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-06-12mpc512x: Add esd gmbh mecp5123 board supportStefan Roese
MECP5123 is a MPC5121E based module by esd gmbh. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-06-1274xx_7xx: CPCI750: Add CPCI adapter/target supportStefan Roese
The CPCI750 can be built as CPCI host or adapter/target board. This patch adds support for runtime detection of those variants. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-06-1274xx_7xx: CPCI750: Enable access to PCI function > 0Stefan Roese
The Marvell bridge 64360 supports serveral PCI functions, not only 0. This patch enables access to those functions. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-06-1274xx_7xx: CPCI750: Minor coding style cleanup of cpci750.cStefan Roese
2009-06-1274xx_7xx: CPCI750: Add loadpci commandStefan Roese
This command is used to load/boot an OS-image which is transferred from the CPCI host to the CPCI target/adapter. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-124xx: Add support for DP405 hardware variantsMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from DP405 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on DP405 boards. Because u-boot with an external cpld bitstream may not take more space in flash than before the u-boot binary is shrinked a little bit. Some unused featues have been removed therefore. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from VOM405 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on VOM405 boards. Because u-boot with an external cpld bitstream may not take more space in flash than before the u-boot binary is shrinked a little bit. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from PMC405 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on PMC405 boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from CMS700 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on CMS700 boards. Because u-boot with an external cpld bitstream may not take more space in flash than before the u-boot binary is shrinked a little bit. Some unused featues have been removed therefore. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12esd/common: extend cpld command with address parameterMatthias Fuchs
This patch adds support for an address parameter to esd's cpld command. This is in preparation to remove compiled-in binary cpld (xsvf) bitstreams. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12i2c: Update references to individual i2c commandsPeter Tyser
The individual i2c commands imd, imm, inm, imw, icrc32, iprobe, iloop, and isdram are no longer available so all references to them have been updated to the new form of "i2c <cmd>". Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12cpci750: i2c cleanupPeter Tyser
The following changes were made, primarily to bring the cpci750 i2c driver in line with U-Boot's current I2C API: - Made i2c_init() globally accessible - Made i2c_read() and i2c_write() return an integer - Updated i2c_init() calls to pass in CONFIG_SYS_I2C_SLAVE in the offhand chance someone adds slave support in the future Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20ppc4xx: Use correct io accessors for esd 405/440 boardsMatthias Fuchs
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32 macros. Also volatile pointer references are replaced by the new accessors. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Use correct io accessors for esd 405 boardsMatthias Fuchs
2009-03-20ppc4xx: Cleanup linker scripts of esd 4xx boardsMatthias Fuchs
2009-03-20ppc4xx: Update TEXT_BASE for DASA_SIM boardsMatthias Fuchs
Fix building DASA_SIM boards by increasing U-Boot's size in flash. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: DU405 maintenance fixMatthias Fuchs
-strip unused features -fix resetting phy Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-17ppc4xx: PMC440: Only use one CS (rank) in DDR2 configurationStefan Roese
This patch fixes a problem spotted by Mikhail Zolotaryov on Sequoia with the DDR2 configuration to only use one CS (rank). As this code is most likely copied from the original Sequoia version, this error was copied as well. Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-18ppc4xx: Some more PMC405 coding-style cleanupStefan Roese
2009-02-18ppc4xx: Update PMC405 board supportMatthias Fuchs
This patch prepares the good old PMC405 board support for upcoming PMC405V2 patches. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-18ppc4xx: Cleanup PMC405 board supportMatthias Fuchs
This patch fixes coding style for PMC405 board support. Also some unneeded features/code is removed. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-14ppc4xx: Add loadpci command to esd's CPCI4052 and CPCI405AB boardsMatthias Fuchs
This patch adds esd's loadpci BSP command to CPCI4052 and CPCI405AB board. This requires CONFIG_CMD_BSP and CONFIG_PRAM. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-14ppc4xx: Disable pci node in device tree on CPCI405 pci adaptersMatthias Fuchs
2009-01-14ppc4xx: Cleanup CPCI405 board codeMatthias Fuchs
This patch cleans up CPCI405 board support: - wrap long lines - unification of spaces in function calls - remove dead code Use correct io accessors on peripherals. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-14ppc4xx: Enable auto RS485 mode on PLU405 boardsMatthias Fuchs
This patch turns on the auto RS485 mode in the 2nd external uart on PLU405 boards. This is a special mode of the used Exar XR16C2850 uart. Because these boards only have a 485 physical layer connected it's a good idea to turn it on by default. Signed-off-by: Matthias Fuchs <mf@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2008-12-14Fix new found CFG_Jean-Christophe PLAGNIOL-VILLARD
Also fix some minor typos. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-10ppc4xx: Disable EEPROM write access on PMC440 boardsMatthias Fuchs
This patch disables EEPROM wrtie access by default on PMC440 board. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-12-10ppc4xx: Fix Ethernet PHY LED configuration on PMC440 boardsMatthias Fuchs
2008-12-10ppc4xx: Update TEXT_BASE for CPCI405 boardsMatthias Fuchs
This patch fixes building U-Boot for CPCI405 boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-25ppc4xx: Use correct io accessors for PCI405Matthias Fuchs
2008-11-25ppc4xx: Remove unused code from PCI405 codeMatthias Fuchs
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Update PMC440 board supportMatthias Fuchs
This patch brings PMC440 board support up to date: - fix GPIO configuration - add misc_init_f() - use better values for usbact variable - fix USB 2.0 phy reset sequence - shrink BAR2 to save PCI address space - add FDT support Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Fix PMC440 BSP commandsMatthias Fuchs
This patch fixes the PMC440 BSP commands painit and selfreset Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Fix esd loadpci commandMatthias Fuchs
This patch fixes esd's loadpci command when not all memory on adapter boards is accessable via PCI. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Clean up PMC440 headerMatthias Fuchs
-Codingstyle cleanup -Remove unused GPIO define Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Handle other board variant in PMC440 FPGA codeMatthias Fuchs
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
