Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
'bool' is defined in random places. This patch consolidates them into a
single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with
true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true.
Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun <yorksun@freescale.com>
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Only define enabled clocks in the config file and enable
the clocks in common code.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Remove CSx configurations from board code and only define
required CSx macros in the board config file to configure
chip select windows and parameters.
When printing all variables with env print, don't print variables that
begin with '.'. If env print is called with a '-a' switch, then
include variables that begin with '.' (just like the ls command).
Variables printed explicitly will be printed even without the -a.
Move the getenv_yesno() to env_common.c and change most checks for
'y' or 'n' to use this helper.
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Add section for the linker-generated lists into all possible linker
files, so that everyone can easily use these lists. This is mostly
a mechanical adjustment.
This changes input_data() and friends from static function to global symbols
under weak alias, to enable board specific overrides (and therefore get rid of
board-specific code in cmd_ide.c)
Also declare ide_bus_offset in the header file, so other files can use
ATA_CURR_BASE as well.
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Replace the in-place ad-hoc implementation of serial_puts() within
the drivers with default_serial_puts() call. This cuts down on the
code duplication quite a bit.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Tom Rini <trini@ti.com>
The env_ptr is already declared in environment.h, so there is no need to
redeclare in board files (especially after including the environment.h)
Remove those declarations.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Remove the support for not-CONFIG_SERIAL_MULTI part from serial
port drivers and some board files. Since CONFIG_SERIAL_MULTI is
now enabled by default, that part is a dead code. Remove it.
Implement support for CONFIG_SERIAL_MULTI into cpci750 serial driver.
This driver was so far only usable directly, but this patch also adds
support for the multi method. This allows using more than one serial
driver alongside the cpci750 driver. Also, add a weak implementation
of default_serial_console() returning this driver.
These are all the files which use the API incorrectly but did not get
built using MAKEALL -a powerpc|arm. I have no compiler for them, but
the remaining issues should be far less than without this patch.
Any outstanding issues are left to the maintainers of boards that use
these drivers.
Some copy/pasted drivers redefine functions
defined in include/net.h. Remove these so that
the definitions can be changed without error.
Fix this:
cpci405.c: In function 'do_get_bpip':
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 3 has type 'IPaddr_t'
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 4 has type 'IPaddr_t'
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 5 has type 'IPaddr_t'
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 6 has type 'IPaddr_t'
cpci405.c:700:8: warning: unused variable 'bd'
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
two boards were redeclaring pciauto_region_allocate() in their local
scope for no obvious reason, the function is in <pci.h> anyway,
this is probably just copying artifacts and old cruft.
A few subsystems are using the same define "NAMESIZE". This has been
working so far because they define it to the same number. However, I
want to change the size of eth_device's NAMESIZE, so rather than tweak
the define names, simply drop references to it. Almost no one does,
and the handful that do can easily be changed to a sizeof().
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750.
As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3,
the device must be swapped.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
This function was defined as an extern in net/eth.c, drop that and use
standard means of calling it.
Boards can select either the 'built-in' parser or the hush parser. We
should not call builtin_run_command() if we are using the hush parser.
We use run_command() instead, since it knows how to call the correct
parser.
The current run_command() is only one of the parsing options - the other
is hush. We should not call run_command() when the hush parser is being
used. So we rename this function to better explain its purpose.
Fixing build regressions for the Integrator I get find that a few
boards try to work around the missing declaration of
pciauto_config_init() by declaring it in the local scope. This
does not make sense when the sibling functions are in <pci.h>
so move the function to the header, ridding the build error
in the Integrator and getting rid of the local declarations
here and there.
Reported-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
* 'next' of ../next:
mkenvimage: Add version info switch (-V)
mkenvimage: Fix getopt() error handling
mkenvimage: Fix some typos
phy: add Micrel KS8721BL phy definition
net: introduce per device index
mvgbe: remove setting of ethaddr within the driver
x86: Add support for specifying an initrd with the zboot command
x86: Refactor the zboot innards so they can be reused with a vboot image
x86: Add infrastructure to extract an e820 table from the coreboot tables
x86: Add support for booting Linux using the 32 bit boot protocol
x86: Clean up the x86 zimage code in preparation to extend it
x86: Import code from coreboot's libpayload to parse the coreboot table
x86: Initial commit for running as a coreboot payload
CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c
CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c
CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c
CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c
CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/hh405/fpgadata.c
CHECKPATCH: ./board/esd/pci405/fpgadata.c
CHECKPATCH: ./board/esd/tasreg/fpgadata.c
CHECKPATCH: ./board/esd/apc405/fpgadata.c
CHECKPATCH: ./board/esd/voh405/fpgadata.c
CHECKPATCH: ./board/esd/ash405/fpgadata.c
CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c
CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c
CHECKPATCH: ./board/esd/ar405/fpgadata.c
CHECKPATCH: ./board/esd/plu405/fpgadata.c
CHECKPATCH: ./board/esd/wuh405/fpgadata.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c
CHECKPATCH: ./board/esd/canbt/fpgadata.c
CHECKPATCH: ./board/esd/du405/fpgadata.c
CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c
CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c
avr32:mmu.c: fix printf() length modifier
fat.c: fix printf() length modifier
cmd_sf.c: fix printf() length modifier
Make printf and vprintf safe from buffer overruns
vsprintf: Move function documentation into header file
Add safe vsnprintf and snprintf library functions
Move vsprintf functions into their own header
tools/mkenvimage.c
Fix:
mv_eth.c: In function 'mv64360_eth_real_open':
mv_eth.c:425:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_stop':
mv_eth.c:643:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_xmit':
mv_eth.c:719:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_receive':
mv_eth.c:804:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_get_stats':
mv_eth.c:903:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_update_stat':
mv_eth.c:931:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
mv_eth.c:930:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_print_stat':
mv_eth.c:1012:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'eth_clear_mib_counters':
mv_eth.c:2069:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable
Cc: Reinhard Arlt <reinhard.arlt@esd.eu>
Acked-by: Anatolij Gustschin <agust@denx.de>
