path: root/board/esd
2004-09-16Fix [noeol] problem in board/esd/ar405/fpgadata_xl30.cwdenk
2004-09-16Update AR405 board.stroese
2004-09-16esd misc file esd common routines added.stroese
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2003-09-12PMC405 update.stroese
2003-09-12PCI405 update.stroese
2003-09-12CPCI405(AB) update.stroese
2003-09-12ASH405 update.stroese
2003-09-12Xilinx jtag tool added.stroese
2003-09-12Board VOH405 added.stroese
2003-09-12Board PLU405 added.stroese
2003-09-12Board HUB405 added.stroese
2003-09-12Board DP405 added.stroese
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-07-11- Fixed interrupt polarity.stroese
2003-07-11- FPGA updated.stroese
2003-07-11- BSP command added.stroese
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-24- Update NAND FLASH support.stroese
2003-06-24- Update new fpga file.stroese
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-06-06- Update new fpga file.stroese
2003-05-23PMC405 board added.stroese
2003-05-23Code cleanup.stroese
2003-05-23New FPGA image with 527 support.stroese
2003-05-23Local Bus Timeout increased.stroese
2003-05-23Code reworked for PPC405EP support.stroese
2003-05-23CPCI405AB (special version of esd CPCI405) board added.stroese
2003-05-23ASH405 board added (PPC405EP based).stroese
2003-04-04Changed CPCI405 to use CTS instead of DSR on PPC405 UART1.stroese
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-26esd PCI405 updated.stroese
2003-03-25esd PCI405 updated.stroese
2003-03-20CPCI4052 update (support for revision 3).stroese
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-09-20Initial revisionwdenk
2002-09-18Initial revisionwdenk
2002-08-30Initial revisionwdenk
2002-08-26Initial revisionwdenk
2002-08-14Initial revisionwdenk
