path: root/board/esd
2011-12-18CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefan Roese <sr@denx.de>
2011-12-18CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/hh405/fpgadata.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-12-18CHECKPATCH: ./board/esd/pci405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/tasreg/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/apc405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/voh405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/ash405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/dasa_sim/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/ar405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/plu405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/wuh405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/canbt/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/du405/fpgadata.cMarek Vasut
2011-12-18CHECKPATCH: ./board/esd/cpciiser4/fpgadata.cMarek Vasut
2011-12-07board/esd/cpci405/cpci405.c: Fix GCC 4.6 warningMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2011-12-02board/esd/dasa_sim/flash.c: Fix GCC 4.6 warningMatthias Fuchs
2011-12-02board/esd/common/xilinx_jtag_micro.c: Fix GCC 4.6 warningMatthias Fuchs
2011-12-01ppc4xx: fix PMC440 painit commandMatthias Fuchs
This patch fixes the PMC440 BSP command painit. The implementation was broken since the step to the new environment handling. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2011-12-01ppc4xx: remove invalid access to PCI_BRDGOPT2 registerMatthias Fuchs
This patch removes an invalid call to pci_write_config_dword to PCI_BRDGOPT2 register. This function must not be used from pci_target_init and is also at the wrong place. The correct call is done later in pci_target_init via pci_hose_write_config_dword. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2011-12-01ppc4xx: use CONFIG_PCI_BOOTDELAY instead of private implementationMatthias Fuchs
This patch switches PMC440 board code to the CONFIG_PCI_BOOTDELAY option instead of using a private implemention. This relies on Anatolji's patch that moves the pcidelay handling behind pci_target_init. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-27Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-16auto_update.c: Fix GCC 4.6 build warningsStefan Roese
Fix: ../common/auto_update.c: In function 'au_check_header_valid': ../common/auto_update.c:94:16: warning: variable 'checksum' set but not used [-Wunused-but-set-variable] ../common/auto_update.c: In function 'do_auto_update': ../common/auto_update.c:400:30: warning: variable 'got_ctrlc' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-16cmd_dasa_sim.c: Fix GCC 4.6 build warningsStefan Roese
Fix: cmd_dasa_sim.c: In function 'updatePci9054': cmd_dasa_sim.c:135:6: warning: variable 'val' set but not used [-Wunused-but-set-variable] cmd_dasa_sim.c: In function 'clearPci9054': cmd_dasa_sim.c:189:6: warning: variable 'val' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-16cmd_pci405.c: Fix GCC 4.6 build warningsStefan Roese
Fix: cmd_pci405.c: In function 'do_loadpci': cmd_pci405.c:45:6: warning: variable 'status' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-16board/esd/cpci750/sdram_init.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: sdram_init.c: In function 'check_dimm': sdram_init.c:267:50: warning: variable 'trrd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:267:37: warning: variable 'tras_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:267:24: warning: variable 'trcd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:267:8: warning: variable 'trp_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:253:16: warning: variable 'spd_checksum' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'initdram': sdram_init.c:1693:14: warning: variable 's1' set but not used [-Wunused-but-set-variable] sdram_init.c:1693:6: warning: variable 's0' set but not used [-Wunused-but-set-variable] Biggest part o the fix is converting the custom debug code to standard debug(). No attempts were made to cleanup the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2011-11-16board/esd/cpci750/cpci750.c: Fix error handlingWolfgang Denk
ThE code recorded error conditions but did not pass these on to the higher level caller. Fixing this fixes also this build warning: cpci750.c: In function 'do_loadpci': cpci750.c:569:6: warning: variable 'status' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2011-11-07board/esd/pf5200/pf5200.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: pf5200.c: In function 'do_phypower': pf5200.c:330:6: warning: variable 'status' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2011-11-07board/esd/cpci5200/strataflash.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: strataflash.c: In function 'flash_write_cfiword': strataflash.c:681:11: warning: variable 'ctladdr' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2011-10-27GCC4.6: Squash warnings in pmc405de.cMarek Vasut
pmc405de.c: In function 'do_painit': pmc405de.c:444: warning: format '%08x' expects type 'unsigned int', but argument 2 has type 'phys_size_t' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-27GCC4.6: Squash warning in cmd_pmc440.cMarek Vasut
cmd_pmc440.c: In function 'do_painit': cmd_pmc440.c:371: warning: format '%08x' expects type 'unsigned int', but argument 2 has type 'phys_size_t' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-19ColdFire: Cleanup lds files for multiple defined symbolsstany MARCEL
Lds files cleened to remove multiple defined section and modified to be compliant with --gc-sections added for ColdFire platform in a previous patch. Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-03at91: reworked support for meesc boardMatthias Fuchs
The meesc board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Matthias Fuchs <Matthias.Fuchs@esd.eu>
2011-05-18at91: reworked support for otc570 boardDaniel Gorsulowski
The otc570 board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-12-09Move LDSCRIPT definitions to board config files.Wolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only LDSCRIPT definitions. Move these into th respective board config files and remove the now empty config.mk files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Detlev Zundel <dzu@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Peter De Schrijver <p2@mind.be> Acked-by: Detlev Zundel < dzu@denx.de> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher<hs@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_bootm: unify duplicate prototypesMike Frysinger
The duplication of the do_bootm prototype has gotten out of hand, and they're pretty much all outdated (wrt constness). Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-2774xx_7xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-11-27ppc4xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
This commit adapts 4xx boards for partial linking with --gc-sections. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: David Updegraff <dave@cray.com> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Larry Johnson <lrj@acm.org> Cc: Peter De Schrijver <p2@mind.be> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Daniel Poirot <dan.poirot@windriver.com> Acked-by: Stefan Roese <sr@denx.de>
