Modify all existing *.c files to use the new register names
as seen in the AMCC manuals.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
This patch adds support to detect the amount of DDR2 SDRAM
on PMC440 modules. Detection is done by probing through
a list of available and supported hardware configurations
from 1GByte down to 256MB.
The static TLB entry is replaced by dynamically created entries.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
The latest PPC4xx register cleanup patch missed the UIC defines.
This patch now changes lower case UIC defines to upper case.
Signed-off-by: Martha M Stan <mmarx@silicontkx.com>
Minor cleanup:
Re-ordered default_mddrc_config[] to have matching indices.
This allows to use the same index "N" for source and target fields;
before, we had code like this
out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]);
which always looked like a copy & paste error because 2 != 3.
Also, use NULL when meaning a null pointer.
Fix warning: ide.c:54: warning: dereferencing type-punned pointer will
break strict-aliasing rules
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Stefan Roese <sr@denx.de>
Fix warning: ../common/flash.c:635: warning: dereferencing type-punned
pointer will break strict-aliasing rules
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
This patch fixes PMC405DE support. Patch 85d6bf0b fixed out-of-tree
building for this board but the loadpci object did not get linked
after that.
It was brought to our attention that U-Boot contains code derived from the
IBM OpenBIOS source code originally provided with some of the older PowerPC
4xx development boards. As a result, the original license of this code has
been carried in the various files for a number of years in the U-Boot project.
IBM is dual-licensing the IBM code contributions already present in U-Boot
under either the terms of the GNU General Public License version 2, or the
original code license already present.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
This patch adds support for the esd VME8349 board equipped with the
MPC8349. It's a VME PMC carrier board equipped with the Tundra
TSI148 VME-bridge.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Some Coding style cleanup (braces, whitespaces, long lines)
Commit bc0d3296 removed ppc_error_no.h from Marvell boards
but forgot to update board/esd/cpci750/mv_eth.h
Now that we have 3 boards for the MPC512x it turns out that they all
use the very same fixed_sdram() code.
This patch factors out this common code into cpu/mpc512x/fixed_sdram.c
and adds a new header file, include/asm-ppc/mpc512x.h, with some
macros, inline functions and prototype definitions specific to MPC512x
systems.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
The mecp5123 board did not compile because the MSCAN Clock Control
Registers were missing; these got added, but as an array instead
of 4 individual registers. Adapt the code so it builds.
This patch adds support for esd gmbh MEESC board.
The MEESC is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
MECP5123 is a MPC5121E based module by esd gmbh.
The CPCI750 can be built as CPCI host or adapter/target board. This patch
adds support for runtime detection of those variants.
The Marvell bridge 64360 supports serveral PCI functions, not only 0. This
patch enables access to those functions.
This command is used to load/boot an OS-image which is transferred from
the CPCI host to the CPCI target/adapter.
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
This patch removes the cpld binary bitstream that is
used by esd's cpld command on DP405 boards.
Because u-boot with an external cpld bitstream may not
take more space in flash than before the u-boot binary is
shrinked a little bit. Some unused featues have been
removed therefore.
used by esd's cpld command on VOM405 boards.
used by esd's cpld command on PMC405 boards.
used by esd's cpld command on CMS700 boards.
removed therefore.
This patch adds support for an address parameter to esd's
cpld command. This is in preparation to remove compiled-in
binary cpld (xsvf) bitstreams.
The individual i2c commands imd, imm, inm, imw, icrc32, iprobe, iloop,
and isdram are no longer available so all references to them have been
updated to the new form of "i2c <cmd>".
The following changes were made, primarily to bring the cpci750 i2c
driver in line with U-Boot's current I2C API:
- Made i2c_init() globally accessible
- Made i2c_read() and i2c_write() return an integer
- Updated i2c_init() calls to pass in CONFIG_SYS_I2C_SLAVE in the
offhand chance someone adds slave support in the future
Signed-off-by: Detlev Zundel <dzu@denx.de>
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32
macros. Also volatile pointer references are replaced by the
new accessors.
new accessors.
Fix building DASA_SIM boards by increasing U-Boot's size in flash.
-strip unused features
-fix resetting phy
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
This patch fixes a problem spotted by Mikhail Zolotaryov on Sequoia with
the DDR2 configuration to only use one CS (rank). As this code is most
likely copied from the original Sequoia version, this error was copied
as well.
This patch prepares the good old PMC405 board support for
upcoming PMC405V2 patches.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fixes coding style for PMC405 board support.
Also some unneeded features/code is removed.
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and
can be confusing when reading the code.
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used
for system memory mapping purposes.
