index
u-boot-toradex.git
2011.12-colibri_vf
2014.04-toradex
2014.10-toradex
2014.10-toradex-next
2015.04-imx7-1.1.0_ga-toradex-next
2015.04-toradex
2015.04-toradex-next
2016.11-toradex
2016.11-toradex-next
colibri
colibri-next
colibri_vf
toradex_2019.07
toradex_2019.07-next
toradex_2020.07
toradex_imx6
toradex_imx_lf_v2022.04
toradex_imx_v2017.03_4.9.123_imx8mm_ga-bring_up
toradex_imx_v2017.03_4.9.51_imx8_beta1-bring_up
toradex_imx_v2017.03_4.9.51_imx8_beta2-bring_up
toradex_imx_v2018.03_4.14.62_1.0.0_beta-bringup
toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup
toradex_imx_v2018.03_4.14.98_2.3.0_bringup
toradex_imx_v2020.04_5.4.24_2.1.0
toradex_imx_v2020.04_5.4.70_2.3.0
toradex_ti-u-boot-2021.01_bringup
toradex_ti-u-boot-2023.04
U-Boot bootloader for Apalis and Colibri modules
Toradex AG
summary
refs
log
tree
commit
diff
log msg
author
committer
range
path:
root
board
esd
Age
Commit message (
Collapse
Author
2003-05-23
PMC405 board added.
stroese
2003-05-23
Code cleanup.
stroese
2003-05-23
New FPGA image with 527 support.
stroese
2003-05-23
Local Bus Timeout increased.
stroese
2003-05-23
Code reworked for PPC405EP support.
stroese
2003-05-23
CPCI405AB (special version of esd CPCI405) board added.
stroese
2003-05-23
ASH405 board added (PPC405EP based).
stroese
2003-04-04
Changed CPCI405 to use CTS instead of DSR on PPC405 UART1.
stroese
2003-03-26
Make compile clean, fix the usual small problems.
LABEL_2003_03_26_1300
wdenk
2003-03-26
esd PCI405 updated.
stroese
2003-03-25
esd PCI405 updated.
stroese
2003-03-20
CPCI4052 update (support for revision 3).
stroese
2003-02-14
Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).
stroese
2002-11-03
Initial revision
wdenk
2002-11-03
Initial revision
wdenk
2002-11-03
Initial revision
wdenk
2002-09-20
Initial revision
wdenk
2002-09-18
Initial revision
wdenk
2002-08-30
Initial revision
wdenk
2002-08-26
Initial revision
wdenk
2002-08-17
Initial revision
wdenk
2002-08-14
Initial revision
wdenk
2002-08-06
Initial revision
wdenk
2002-07-20
Initial revision
wdenk
2002-07-18
Initial revision
wdenk
2002-07-07
Initial revision
wdenk
2002-06-07
Initial revision
wdenk
2002-05-15
Initial revision
wdenk
2002-04-01
Initial revision
wdenk
2002-03-02
Initial revision
wdenk
2001-12-28
Initial revision
wdenk
2001-11-26
Initial revision
wdenk
2001-10-15
Initial revision
wdenk
2001-10-07
Initial revision
wdenk
2001-08-05
Initial revision
wdenk
2001-07-19
Initial revision
wdenk
