path: root/board/esd
2003-06-24- Update NAND FLASH support.stroese
2003-06-24- Update new fpga file.stroese
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-06-06- Update new fpga file.stroese
2003-05-23PMC405 board added.stroese
2003-05-23Code cleanup.stroese
2003-05-23New FPGA image with 527 support.stroese
2003-05-23Local Bus Timeout increased.stroese
2003-05-23Code reworked for PPC405EP support.stroese
2003-05-23CPCI405AB (special version of esd CPCI405) board added.stroese
2003-05-23ASH405 board added (PPC405EP based).stroese
2003-04-04Changed CPCI405 to use CTS instead of DSR on PPC405 UART1.stroese
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-26esd PCI405 updated.stroese
2003-03-25esd PCI405 updated.stroese
2003-03-20CPCI4052 update (support for revision 3).stroese
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-09-20Initial revisionwdenk
2002-09-18Initial revisionwdenk
2002-08-30Initial revisionwdenk
2002-08-26Initial revisionwdenk
2002-08-14Initial revisionwdenk
2002-08-06Initial revisionwdenk
2002-07-18Initial revisionwdenk
2002-07-07Initial revisionwdenk
2002-06-07Initial revisionwdenk
2002-05-15Initial revisionwdenk
2002-04-01Initial revisionwdenk
2002-03-02Initial revisionwdenk
2001-12-28Initial revisionwdenk
2001-11-26Initial revisionwdenk
2001-10-15Initial revisionwdenk
2001-10-07Initial revisionwdenk
2001-08-05Initial revisionwdenk
2001-07-19Initial revisionwdenk
