board/esd/dasa_sim/dasa_sim.c
This patch adds initdram() to DASA_SIM boards that has been
removed accidentally by a previous commit.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch removes some direct references to common/lists.o from some
esd linker scripts. This is necessary because the lists source was moved
and is not in the "common" directory anymore.
This patch removes initdram() and testdram() from most esd 405 platforms.
Some boards also have an empty dummy implementation of
misc_init_f(). This is also removed.
This patch removed the obsolete initdram() function from
VOM405 platform file.
Some minor cleanup.
This patch
- wraps some long lines
- removes unused/obsolete functions: misc_init_f() and initdram()
Signed-off-by: Matthias Fuchs <mf@esd.eu>
Affected boards:
cu824
bab7xx
adciop
dasa_sim
mousse
mpc8540eval
musenki
mvblue
pcippc2/pcippc6
sbc8240
stxssa
Removed initialization of the driver from net/eth.c
Affected boards:
bc3450
cpci5200
mecp5200
pf2000
icecube
o2dnt
pm520
sandpoint8245
total5200
tqm5200
There is no point in disabling the icache on 7xx/74xx/86xx parts and not
also flushing the icache. All callers of invalidate_l1_instruction_cache()
call icache_disable() right after. Make it so icache_disable() calls
invalidate_l1_instruction_cache() for us.
Also, dcache_disable() already calls dcache_flush() so there is no point
in the explicit calls of dcache_flush().
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
- Fixing leading white spaces
- Fixing indentation where 4 spaces are used instead of tab
- Removing C++ comments (//), wherever I introduced them
Signed-off-by: William Juul <william.juul@tandberg.com>
A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
TASREG is ColdFire platform, the include ppc4xx.h in
board/esd/common/flash.c causes conflict.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
This patch removes some ft_board_setup() functions from some 4xx boards.
This can be done since we now have a default weak implementation for this
in cpu/ppc4xx/fdt.c. Only board in need for a different/custom
implementation like canyonlands need their own version.
This patch fixes ppc4xx related printf format warning. Those warnings are
now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd
[Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is
really helpful.
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Historically the 405 U-Boot port had a dram_init() call in early init
stage. This function was still called from start.S and most of the time
coded in assembler. This is not needed anymore (since a long time) and
boards should implement the common initdram() function in C instead.
This patch now removed the dram_init() call from start.S and removes the
empty implementations that are scattered through most of the 405 board
ports. Some older board ports really implement this dram_init() though.
These are:
csb272
csb472
ERIC
EXBITGEN
W7OLMC
W7OLMG
I changed those boards to call this assembler dram_init() function now
from their board specific initdram() instead. This *should* work, but please
test again on those platforms. And it is perhaps a good idea that those
boards use some common 405 SDRAM initialization code from cpu/ppc4xx at
some time. So further patches welcome here.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Several board/<...>/config.mk files include dynamically built (by
the Makefile) config files but used the wrong file name of
$(TOPDIR)/board/$(BOARDDIR)/config.tmp
instead if the correct
$(OBJTREE)/board/$(BOARDDIR)/config.tmp
The bug is nasty because the build result is correct for the (normal)
in-tree builds, and because 'sinclude' is used no errors get raised
even for out-of-tree build tests. But out-of-tree builds use an
incomplete and thus usually incorrect configuration...
This patch removes the temporary 'test' strapping option
of the sbe command. The '667' strapping option now uses
a PLB/PCI divider of 3.
The APC405 board support has been migrated to use the common
CFI flash driver.
- enable esd's auto_update mechanism
- fix LCD support on latest hardware revision (uses other LCD controller)
- support alternative flash layout on rev. 1.8 boards
- coding style cleanup
- Coding style cleanup (long lines)
- improve handling of protected flash regions
- remove dead code
- Add s1d13505 support
- Make some functions return a result code instead of void
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Add support for the ptm1la, ptm1ms, ptm2la and ptm2ms
environment variables.
Cleanup pci_target_init.
pointer target type
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
This patch updates the PLB/PCI divider when running at
400MHz CPU frequency from 4 to 3 which results in 44MHz PCI sync clock.
