Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32
macros. Also volatile pointer references are replaced by the
new accessors.
This patch disables EEPROM wrtie access by default on PMC440 board.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch brings PMC440 board support up to date:
- fix GPIO configuration
- add misc_init_f()
- use better values for usbact variable
- fix USB 2.0 phy reset sequence
- shrink BAR2 to save PCI address space
- add FDT support
This patch removes some ft_board_setup() functions from some 4xx boards.
This can be done since we now have a default weak implementation for this
in cpu/ppc4xx/fdt.c. Only board in need for a different/custom
implementation like canyonlands need their own version.
Add support for the ptm1la, ptm1ms, ptm2la and ptm2ms
environment variables.
Cleanup pci_target_init.
This patch adds the first files for the new esd PMC440 boards.
The next two patches will complete the PMC440 board support.
