2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-06-25 | * Header file cleanup for ARMLABEL_2003_06_26_2220 | wdenk | |
* Patch by Murray Jensen, 24 Jun 2003: - make sure to use only U-boot provided header files - fix problems with ".rodata.str1.4" section as used by GCC-3.x | |||
2003-05-30 | * Get (mostly) rid of CFG_MONITOR_LEN definition; compute real lengthLABEL_2003_05_30_1450 | wdenk | |
instead CFG_MONITOR_LEN is now only used to determine _at_compile_ _time_ (!) if the environment is embedded within the U-Boot image, or in a separate flash sector. * Cleanup CFG_DER #defines in config files (wd maintained only) | |||
2003-05-23 | Code cleanup. | stroese | |
2003-05-23 | New FPGA image with 527 support. | stroese | |
2003-05-23 | Local Bus Timeout increased. | stroese | |
2003-03-26 | Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300 | wdenk | |
2003-03-26 | esd PCI405 updated. | stroese | |
2003-03-25 | esd PCI405 updated. | stroese | |
2002-11-03 | Initial revision | wdenk | |
2002-08-17 | Initial revision | wdenk | |
2002-07-20 | Initial revision | wdenk | |
2002-07-07 | Initial revision | wdenk | |
2002-06-07 | Initial revision | wdenk | |
