path: root/board/esd/meesc
2012-02-27at91: modified NAND flash timing on meesc boardDaniel Gorsulowski
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-03at91: reworked support for meesc boardMatthias Fuchs
The meesc board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Matthias Fuchs <Matthias.Fuchs@esd.eu>
2010-08-20at91: Enabeling USB host on meesc boardDaniel Gorsulowski
There was an redesign, so USB is available now. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-20at91: Update meesc board to new SoC accessDaniel Gorsulowski
* convert meesc board to use c stucture SoC access * change gpio access to at91_gpio syntax * moved CONFIG_SYS_HZ below board and cpu defines (purely cosmetic) Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-01-23at91: Enable slow master clock on meesc boardDaniel Gorsulowski
Normally the processor clock has a divisor of 2. In some cases this this needs to be set to 4. Check the user has set environment mdiv to 4 to change the divisor. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-10-13at91: Update MEESC board supportDaniel Gorsulowski
This patch implements several updates: -disable CONFIG_ENV_OVERWRITE -add new hardware style variants and set the arch numbers appropriate -pass the serial# and hardware revision to the kernel -removed unused macros from include/configs/meesc.h -fixed multiline comment style Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-07-06at91: Add esd gmbh MEESC board supportDaniel Gorsulowski
This patch adds support for esd gmbh MEESC board. The MEESC is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
