path: root/board/esd/mecp5123
2009-12-085xxx, fdt: move fdt_fixup_memory() to cpu.c fileHeiko Schocher
u-boot updates, before starting Linux, the memory node in the DTS. As this is a "standard" feature, move this functionality to the cpu.c file for mpc5xxx and mpc512x processors. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-25mpc512x: Streamlined fixed_sdram() init sequence.Martha M Stan
Signed-off-by: Martha M Stan <mmarx@silicontkx.com> Minor cleanup: Re-ordered default_mddrc_config[] to have matching indices. This allows to use the same index "N" for source and target fields; before, we had code like this out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]); which always looked like a copy & paste error because 2 != 3. Also, use NULL when meaning a null pointer. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14MPC512x: factor out common codeWolfgang Denk
Now that we have 3 boards for the MPC512x it turns out that they all use the very same fixed_sdram() code. This patch factors out this common code into cpu/mpc512x/fixed_sdram.c and adds a new header file, include/asm-ppc/mpc512x.h, with some macros, inline functions and prototype definitions specific to MPC512x systems. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14mecp5123: fix build errorWolfgang Denk
The mecp5123 board did not compile because the MSCAN Clock Control Registers were missing; these got added, but as an array instead of 4 individual registers. Adapt the code so it builds. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-06-12mpc512x: Add esd gmbh mecp5123 board supportStefan Roese
MECP5123 is a MPC5121E based module by esd gmbh. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
