path: root/board/esd/hub405
2015-01-13ppc4xx: remove HUB405 boardMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Use correct io accessors for esd 405/440 boardsMatthias Fuchs
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32 macros. Also volatile pointer references are replaced by the new accessors. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Cleanup linker scripts of esd 4xx boardsMatthias Fuchs
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Remove obsolete or unused functions from some esd boardsMatthias Fuchs
This patch removes initdram() and testdram() from most esd 405 platforms. Some boards also have an empty dummy implementation of misc_init_f(). This is also removed. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-09Migrate esd 405EP boards to new NAND subsystemMatthias Fuchs
Migrate esd 405EP boards to new NAND subsystem -cleanup -use correct io accessors (in/out_be32()) Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2006-04-12Merge with /home/m8/git/u-bootWolfgang Denk
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-06Minor code cleanupWolfgang Denk
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-03-01Update for esd boards dp405 and hub405stroese
2004-12-16Code cleanup.wdenk
2004-12-16HUB405 board updatestroese
2003-09-12Board HUB405 added.stroese
