path: root/board/esd/du405
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Use correct io accessors for esd 405/440 boardsMatthias Fuchs
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32 macros. Also volatile pointer references are replaced by the new accessors. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Cleanup linker scripts of esd 4xx boardsMatthias Fuchs
2009-03-20ppc4xx: DU405 maintenance fixMatthias Fuchs
-strip unused features -fix resetting phy Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Remove obsolete or unused functions from some esd boardsMatthias Fuchs
This patch removes initdram() and testdram() from most esd 405 platforms. Some boards also have an empty dummy implementation of misc_init_f(). This is also removed. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] PPC4xx: Add support for multiple I2C bussesStefan Roese
This patch adds support for multiple I2C busses on the PPC4xx platforms. Define CONFIG_I2C_MULTI_BUS in the board config file to make use of this feature. It also merges the 405 and 440 i2c header files into one common file 4xx_i2c.h. Also the 4xx i2c reset procedure is reworked since I experienced some problems with the first access on the 440SPe Katmai board. Signed-off-by: Stefan Roese <sr@denx.de>
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-08-12esd WUH405 and DU405 board updatedStefan Roese
Patch by Matthias Fuchs, 27 Jul 2005
2004-12-16DU405 board updatestroese
2002-08-30Initial revisionwdenk
2002-07-07Initial revisionwdenk
2002-03-02Initial revisionwdenk
2001-12-28Initial revisionwdenk
