path: root/board/esd/dasa_sim/flash.c
2014-04-17board: esd: remove remainders of dead boardsMasahiro Yamada
Commit 99bcad18 deleted ADCIOP and DASA_SIM board support but missed to delete board/esd/adciop and board/esd/dasa_sim. It also missed to add entries to doc/README.scrapyard. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2011-12-02board/esd/dasa_sim/flash.c: Fix GCC 4.6 warningMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
