path: root/board/esd/cpciiser4/Makefile
2015-01-13ppc4xx: remove CPCIISER4 boardMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2004-12-16CPCIISER4 board updatestroese
2002-09-18Initial revisionwdenk
