path: root/board/esd/ash405/Makefile
2007-07-09Migrate esd 405EP boards to new NAND subsystemMatthias Fuchs
Migrate esd 405EP boards to new NAND subsystem -cleanup -use correct io accessors (in/out_be32()) Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2004-12-16ASH405 board updatestroese
2003-05-23ASH405 board added (PPC405EP based).stroese
