path: root/board/esd/ar405
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-08-09ppc4xx: Fix building of AR405 boardMatthias Fuchs
Update image size after addition of new environment handling. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20ppc4xx: Use correct io accessors for esd 405 boardsMatthias Fuchs
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32 macros. Also volatile pointer references are replaced by the new accessors. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Cleanup linker scripts of esd 4xx boardsMatthias Fuchs
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Remove reference to common/lists.o from some esd linker scriptsStefan Roese
This patch removes some direct references to common/lists.o from some esd linker scripts. This is necessary because the lists source was moved and is not in the "common" directory anymore. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2004-12-16AR405 board updatestroese
2004-09-16Fix [noeol] problem in board/esd/ar405/fpgadata_xl30.cwdenk
2004-09-16Update AR405 board.stroese
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2003-07-11- FPGA updated.stroese
2002-09-18Initial revisionwdenk
2002-08-30Initial revisionwdenk
2001-11-26Initial revisionwdenk
2001-10-15Initial revisionwdenk
2001-07-19Initial revisionwdenk
