path: root/board/esd/apc405
2011-12-18CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefan Roese <sr@denx.de>
2011-12-18CHECKPATCH: ./board/esd/apc405/fpgadata.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-20cfi_flash: Simplify dynamic flash bank number detectionStefan Roese
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature: APC405, IDS8247, TQM834x And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port. This new framework will be used by the upcoming lwmon5 update as well. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Use correct io accessors for esd 405 boardsMatthias Fuchs
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32 macros. Also volatile pointer references are replaced by the new accessors. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Cleanup linker scripts of esd 4xx boardsMatthias Fuchs
2008-09-03ppc4xx: Remove obsolete or unused functions from some esd boardsMatthias Fuchs
This patch removes initdram() and testdram() from most esd 405 platforms. Some boards also have an empty dummy implementation of misc_init_f(). This is also removed. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-25ppc4xx: Add bootcount limit handling for APC405 boardsMatthias Fuchs
2008-04-22ppc4xx: Remove unused APC405 strataflash driverMatthias Fuchs
The APC405 board support has been migrated to use the common CFI flash driver. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-04-22ppc4xx: Update APC405 board supportMatthias Fuchs
- enable esd's auto_update mechanism - fix LCD support on latest hardware revision (uses other LCD controller) - support alternative flash layout on rev. 1.8 boards - coding style cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-04-22ppc4xx: Update FPGA image for APC405 boardsMatthias Fuchs
2008-04-22ppc4xx: Update bootlogo for APC405 boardsMatthias Fuchs
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-04-13Update for esd apc405stroese
2004-12-16Code cleanup.wdenk
2004-12-16APC405 board support addedstroese
