path: root/board/esd/apc405/Makefile
2008-04-22ppc4xx: Update APC405 board supportMatthias Fuchs
- enable esd's auto_update mechanism - fix LCD support on latest hardware revision (uses other LCD controller) - support alternative flash layout on rev. 1.8 boards - coding style cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2004-12-16APC405 board support addedstroese
