path: root/board/eric
2004-10-24* Fix configuration for ERIC board (needs more room)wdenk
* Adjust MIPS compiler options at run-time depending on tools version ("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new, "-mcpu=4kc" for old tools)
2002-08-26Initial revisionwdenk
2001-05-31Initial revisionwdenk
2001-05-29Initial revisionwdenk
