2003-05-30 | * Get (mostly) rid of CFG_MONITOR_LEN definition; compute real lengthLABEL_2003_05_30_1450 | wdenk | |
instead CFG_MONITOR_LEN is now only used to determine _at_compile_ _time_ (!) if the environment is embedded within the U-Boot image, or in a separate flash sector. * Cleanup CFG_DER #defines in config files (wd maintained only) | |||
2002-11-03 | Initial revision | wdenk | |
2002-08-26 | Initial revision | wdenk | |
2002-07-20 | Initial revision | wdenk | |
2001-05-31 | Initial revision | wdenk | |
2001-05-29 | Initial revision | wdenk | |
