path: root/board/ep88x
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-09EP88x: fix broken linker scriptWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Mikhail Zaturenskiy <mzaturenskiy@shoppertrak.com>
2006-03-12Add support for EmbeddedPlanet EP88x boardsWolfgang Denk
Patch by Yuli Barcohen, 13 Jul 2005
