path: root/board/ep8260
2015-01-05mpc8260: remove ep8260 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Frank Panno <fpanno@delphintech.com>
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2010-12-09Remove redundant config.mk filesWolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only redundant entries like PLATFORM_CPPFLAGS += -I$(TOPDIR) or settings of variables that were not used anywhere in the code, like TEXT_END = 0xfe080000 Remove these unnecessary files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Wolfgang Wegner <w.wegner@astro-kom.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Tolunay Orkun <torkun@nextio.com> Cc: Frank Panno <fpanno@delphintech.com> Cc: Heiko Schocher <hs@denx.de> Cc: Brad Kemp <Brad.Kemp@seranoa.com> Acked-by: Heiko Schocher<hs@denx.de>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-07-04Remove obsolete mpc824x linker scripts (2 of 4)Grant Likely
2005-01-09* Patch by Kurt Stremerch, 03 Sep 2004:wdenk
Add Xilinx Spartan2E family FPGA support * Patch by Jeff Angielski, 02 Sep 2004: Add Added support for H2 revision of the EP8260 board. Fixed formatting for some of the EP8260 related source files.
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2002-08-26Initial revisionwdenk
2002-02-06Initial revisionwdenk
