path: root/board/ep8260
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-07-04Remove obsolete mpc824x linker scripts (2 of 4)Grant Likely
2005-01-09* Patch by Kurt Stremerch, 03 Sep 2004:wdenk
Add Xilinx Spartan2E family FPGA support * Patch by Jeff Angielski, 02 Sep 2004: Add Added support for H2 revision of the EP8260 board. Fixed formatting for some of the EP8260 related source files.
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2002-08-26Initial revisionwdenk
2002-02-06Initial revisionwdenk
