path: root/board/ep8248
2007-07-04Remove obsolete mpc824x linker scripts (2 of 4)Grant Likely
2005-08-06Add support for ep8248 boardWolfgang Denk
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup.
