path: root/board/ep8248
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-09-10ep8248: add support for device tree and secondary Ethernet interface.Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com>
2007-07-04Remove obsolete mpc824x linker scripts (2 of 4)Grant Likely
2005-08-06Add support for ep8248 boardWolfgang Denk
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup.
