path: root/board/enbw
2014-08-30davinci: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Davinci board select menu to davinci/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="davinci"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2014-06-19mtd: nand: davinci: add header file for driver definitionsKhoronzhuk, Ivan
The definitions inside emif_defs.h concern davinci nand driver and should be in it's header. So create header file for davinci nand driver and move definitions from emif_defs.h and nand_defs.h to it. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> [trini: Fixup more davinci breakage] Signed-off-by: Tom Rini <trini@ti.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-01am33xx, davinci: Create and use <asm/davinci_rtc.h>Tom Rini
Create a common header file for the RTC IP block that is shared between davinci and am33xx. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01davinci: enbw_cmc: change switch init behaviourHeiko Schocher
change the behaviour of switch initialization: - rename "pwl" to "lan" in hwconfig parameter "lan" = port 1 with phy addr 2 "lmn" = port 2 with phy addr 3 - if we have a valid switch config file in flash, do not evaluate the settings in the hwconfig "lan" or "lmn" subcommand. - if we have no valid switch config file in flash, start the switch with default values, if we have a "lan" or a "lmn" hwconfig subcommand. If no "lan" or "lmn" is found in hwconfig, do nothing with the switch. Signed-off-by: Heiko Schocher <hs@denx.de>
2012-09-01Consolidate bootcount code into drivers/bootcountStefan Roese
This patch moves all bootcount implementations into a common directory: drivers/bootcount. The generic bootcount driver is now usable not only by powerpc platforms, but others as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de> Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-07arm,davinci: update for enbw_cmc boardHeiko Schocher
- change gpio pin settings: - gpio pin 6[13] (PLC reset) default value low - gpio pin 6[0] (TPM reset) default value low - 4 new GPIO pins pin i/o name - 3[9] input Board Type - 2[7] input HW-ID0 - 2[6] input HW-ID1 - 2[3] input HW-ID2 - read board type and hw id from gpio pins on the enbw_cmc board, and use board type for setting up different gpio pin settings. - do not pass "davinci_mmc.use_dma=0" to linux, as MMC now works with DMA. - update logbuf support: store post word in RTC scratch register - add support for configuring KSZ8864RMN switch through a config file on u-boot startup. For more infos see: doc/README.switch_config Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <tom.rini@gmail.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2012-03-27calimain, enbw_cmc: Fix typo in commentsChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-01-16arm, davinci: Change byte order of RTC kick register valuesChristian Riesch
Now the values in the defines agree with those in the manuals. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de>
2011-12-06arm, davinci: add support for am1808 based enbw_cmc boardHeiko Schocher
- booting from NOR Flash with direct boot method - POST support - LOGBUF support Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Paulraj Sandeep <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Christian Riesch <christian.riesch@omicron.at>
