path: root/board/emulation
2018-12-18riscv: qemu: Imply SIFIVE_SERIAL for emulationAnup Patel
This patch enables SiFive UART driver for QEMU RISC-V emulation by implying SIFIVE_SERIAL on BOARD_SPECIFIC_OPTIONS. Signed-off-by: Anup Patel <anup@brainfault.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-12-18riscv: qemu: Add platform-specific Kconfig optionsBin Meng
Add the QEMU RISC-V platform-specific Kconfig options, to include CPU and timer drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Anup Patel <anup@brainfault.org>
2018-12-05riscv: Add S-mode defconfigs for QEMU virt machineAnup Patel
This patch adds S-mode defconfigs for QEMU virt machine so that we can run u-boot in S-mode on QEMU using M-mode runtime firmware (BBL or equivalent). Signed-off-by: Anup Patel <anup@brainfault.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-12-05riscv: qemu: Use different SYS_TEXT_BASE for S-modeAnup Patel
When u-boot runs in S-mode, the M-mode runtime firmware (BBL or equivalent) uses memory range in 0x80000000 to 0x80200000. Due to this, we cannot use 0x80000000 as SYS_TEXT_BASE when running in S-mode. Instead for S-mode, we use 0x80200000 as SYS_TEXT_BASE. Even Linux RISC-V kernel ignores/reserves memory range 0x80000000 to 0x80200000 because it runs in S-mode. Signed-off-by: Anup Patel <anup@brainfault.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-11-26riscv: qemu: clear kernel-start/-end in device tree as workaround for BBLLukas Auer
QEMU specifies the location of Linux (supplied with the -kernel argument) in the device tree using the riscv,kernel-start and riscv,kernel-end properties. We currently rely on the SBI implementation of BBL to run Linux and therefore embed Linux as payload in BBL. This causes an issue, because BBL detects the kernel properties in the device tree and ignores the Linux payload as a result. Work around this issue by clearing the kernel properties in the device tree before booting Linux. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-11-26riscv: qemu: detect and boot the kernel passed by QEMULukas Auer
QEMU embeds the location of the kernel image in the device tree. Store this address in the environment as variable kernel_start. It is used in the board-local distro boot command QEMU to boot the kernel with the U-Boot device tree. The QEMU boot command is added as the first boot target device. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-11-26riscv: qemu: use device tree passed by prior boot stageLukas Auer
QEMU provides a device tree, which is passed to U-Boot using register a1. We are now able to directly select the device tree with the configuration CONFIG_OF_PRIOR_STAGE. Replace the hard-coded address in qemu-riscv with it. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-11-14x86: qemu: Imply virtio PCI transport and device driversBin Meng
Add virtio drivers for QEMU x86 targets. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14arm: qemu: Enumerate virtio bus during early bootBin Meng
Currently devices on the virtio bus is not automatically enumerated, which means peripherals on the virtio bus are not discovered by their drivers. This uses board_init() to do the virtio enumeration. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14arm: qemu: Add a Kconfig in the board directoryBin Meng
This adds a Kconfig file in the board directory, so that some board-specific options can be specified there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14riscv: qemu: Include some useful commandsBin Meng
With the virtio net and blk drivers, we can do more stuff with some useful commands. Imply those in the board Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14riscv: qemu: Enumerate virtio bus during early bootBin Meng
2018-10-03riscv: Add QEMU virt board supportBin Meng
This adds QEMU RISC-V 'virt' board target support, with the hope of helping people easily test U-Boot on RISC-V. The QEMU virt machine models a generic RISC-V virtual machine with support for the VirtIO standard networking and block storage devices. It has CLINT, PLIC, 16550A UART devices in addition to VirtIO and it also uses device-tree to pass configuration information to guest software. It implements RISC-V privileged architecture spec v1.10. Both 32-bit and 64-bit builds are supported. Support is pretty much preliminary, only booting to U-Boot shell with the UART driver on a single core. Booting Linux is not supported yet. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-09-05ARM: qemu-arm: Fix qemu_arm64_defconfig for QEMU 3.0Tuomas Tynkkynen
QEMU 3.0 introduced additional memory-mapped regions for PCI-E ECAM and MMIO. Thus we need to add them to our MMU map or U-Boot will crash with a Synchronous Abort during PCI-E probing when it tries to access the unmapped ECAM memory area. Reported-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Tested-by: Jonathan Gray <jsg@jsg.id.au>
2018-07-19lib: fdtdec: Rename routine fdtdec_setup_memory_size()Siva Durga Prasad Paladugu
This patch renames the routine fdtdec_setup_memory_size() to fdtdec_setup_mem_size_base() as it now fills the mem base as well along with size. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-06-17x86: Drop QEMU-specific EFI payload supportBin Meng
Now that we have generic EFI payload support for all x86 boards, drop the QEMU-specific one. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-26ARM: qemu-arm: Bump RAM size in AArch64 MMU tableTuomas Tynkkynen
Now that PCI devices work with highmem-enabled QEMU emulation, bump up the RAM size in the MMU tables to gain access to the full 255 GB of RAM potential instead of the puny 3 GB. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-19ARM: qemu-arm: Add support for AArch64Tuomas Tynkkynen
This adds support for '-machine virt' on AArch64. This is rather simple: we just add TARGET_QEMU_ARM_xxBIT to select a few different Kconfig symbols, provide the ARMv8 memory map from the board file and add a new defconfig based on the 32-bit defconfig. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-06ARM: Add a new arch + board for QEMU's 'virt' machineTuomas Tynkkynen
This board builds an U-Boot binary that is bootable with QEMU's 'virt' machine on ARM. The minimal QEMU command line is: qemu-system-arm -machine virt,highmem=off -bios u-boot.bin (Note that the 'highmem=off' parameter to the 'virt' machine is required for PCI to work in U-Boot.) This command line enables the following: - u-boot.bin loaded and executing in the emulated flash at address 0x0 - A generated device tree blob placed at the start of RAM - A freely configurable amount of RAM, described by the DTB - A PL011 serial port, discoverable via the DTB - An ARMv7 architected timer - PSCI for rebooting the system - A generic ECAM-based PCI host controller, discoverable via the DTB Additionally, QEMU allows plugging a bunch of useful peripherals to the PCI bus. The following ones are supported by both U-Boot and Linux: - To add a Serial ATA disk via an Intel ICH9 AHCI controller, pass e.g.: -drive if=none,file=disk.img,id=mydisk -device ich9-ahci,id=ahci -device ide-drive,drive=mydisk,bus=ahci.0 - To add an Intel E1000 network adapter, pass e.g.: -net nic,model=e1000 -net user - To add an EHCI-compliant USB host controller, pass e.g.: -device usb-ehci,id=ehci - To add a NVMe disk, pass e.g.: -drive if=none,file=disk.img,id=mydisk -device nvme,drive=mydisk,serial=foo Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-02-07x86: qemu: Add a config for 64-bit U-BootBin Meng
Add a new board config which uses 64-bit U-Boot. Supported features are the same as the other 64-bit board (Google Chromebook Link). It is a start for us to test 64-bit U-Boot easily without the need to access a real hardware. Note CONFIG_SPL_ENV_SUPPORT is required for QEMU 64-bit as without this the SPL build fails at the end. This is just a workaround as CONFIG_SPL_ENV_SUPPORT is not needed at all. common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate' lib/built-in.o: In function `hsearch_r': lib/hashtable.c:380: undefined reference to 'env_callback_init' lib/hashtable.c:382: undefined reference to 'env_flags_init' make[1]: *** [spl/u-boot-spl] Error 1 Except those SPL options required by 64-bit, compared to 32-bit config, the following options are different: - CONFIG_SYS_MALLOC_F_LEN has to be increased to 0x1000 for SPL. - CONFIG_DEBUG_UART has to be included due to the weird issue. See TODO comments in arch/x86/cpu/x86_64/cpu.c:arch_setup_gd(). Once this issue gets fixed, debug uart can be optional. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-07x86: qemu: Add a text base for 64-bit U-BootBin Meng
Set up the 64-bit U-Boot text base if building for that target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-30x86: qemu: efi: Add two boards for EFI 32-bit and 64-bit payloadBin Meng
This introduces two board defconfig files for generating EFI 32-bit and 64-bit payloads, to run on QEMU x86 target. With these in place, hopefully buildman will catch any build error with EFI payload support on x86. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model ethBin Meng
Move to driver model for ETH (e1000) on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: qemu: Support operation as an EFI payloadSimon Glass
Disable a few things which interfere with the EFI init. This allows QEMU to to boot into EFI, load a U-Boot payload then boot to the U-Boot prompt. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-04x86: Support QEMU x86 targetsBin Meng
This commit introduces the initial U-Boot support for QEMU x86 targets. U-Boot can boot from coreboot as a payload, or directly without coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Merged in patch 'x86: qemu: Add CMD_NET to qemu-x86_defconfig https://patchwork.ozlabs.org/patch/479745/
