path: root/board/emk
2012-03-28atmel-boards: add missing atmel_mci.hAndreas Bießmann
commit 72fa467988e7944407a634ddc4bc6a2df685c04c moved atmel_mci_init() into include/atmel_mci.h. Some AT91 boards are also using this interface and need to include atmel_mci.h now. This patch fixes MAKEALL complaints like this: ---8<--- Configuring for ethernut5 - Board: ethernut5, Options: AT91SAM9XE ethernut5.c: In function 'board_mmc_init': ethernut5.c:235:2: warning: implicit declaration of function 'atmel_mci_init' [-Wimplicit-function-declaration] --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> CC: Albert Aribaud <albert.u.boot@aribaud.net> CC: Reinhard Meyer <u-boot@emk-elektronik.de> CC: egnite GmbH <info@egnite.de>
2012-01-08mmc: Change board_mmc_getcd() function prototype.Thierry Reding
The new API no longer uses the extra cd parameter that was used to store the card presence state. Instead, this information is returned via the function's return value. board_mmc_getcd() returns -1 to indicate that no card-detection mechanism is implemented; 0 indicates that no card is present and 1 is returned if it was detected that a card is present. The rationale for this change can be found in the following email thread: http://lists.denx.de/pipermail/u-boot/2011-November/110180.html In summary, the old API was not consistent with the rest of the MMC API which always passes a struct mmc as the first parameter. Furthermore the cd parameter was used to mean "card absence" in some implementations and "card presence" in others. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Jason Liu <jason.hui@linaro.org>
2011-12-02board/emk/top860/top860.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: top860.c: In function 'initdram': top860.c:90:11: warning: variable 'j' set but not used [-Wunused-but-set-variable] Note: No attempts were made to convert this file completely to using I/O accessors. This is left as an exercise for the board maintainer. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
2011-11-27Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-06-21AT91 rework: fix TOP9000 files to build againReinhard Meyer
Fix EMK TOP9000 board to build again: - changes required due to ATMEL rework Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-12-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-12-17Coding style (white space) cleanup.Wolfgang Denk
2010-12-17AT91: fix TOP9000 build problem and change CONFIG_SYS_TEXT_BASEReinhard Meyer
2010-12-07AT91: add TOP9000 supportReinhard Meyer
Adds support for the EMK TOP9000 CPU Module which is based on ATMELs ARM926EJS AT91SAM9XE SoC. Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-18Fix build errors after making flash_get_info() non-staticWolfgang Denk
Fix for these build problems: error: static declaration of 'flash_get_info' follows non-static declaration Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-04Remove obsolete mpc5xxx linker scripts (2 of 3)Grant Likely
2006-11-30Code cleanup.Wolfgang Denk
2006-11-01- Add MPC5XXX register definition MPC5XXX_WU_GPIO_DATA_I and change theBartlomiej Sieka
MPC5XXX_WU_GPIO_DATA macro to MPC5XXX_WU_GPIO_DATA_O (per MPC5200 User's Manual). Replace the uses of MPC5XXX_WU_GPIO_DATA with MPC5XXX_WU_GPIO_DATA_O for affected boards. - Add defintions for some MPC5XXX GPIO pins.
2004-04-18* Patch by Matthew S. McClintock, 14 Apr 2004:wdenk
fix initdram function for utx8245 board * Patch by Markus Pietrek, 14 Apr 2004: use ATAG_INITRD2 instead of deprecated ATAG_INITRD tag * Patch by Reinhard Meyer, 18 Apr 2004: provide the IDE Reset Function for EMK 5200 boards * Patch by Masami Komiya, 12 Apr 2004: fix pci_hose_write_config_{byte,word}_via_dword problems
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patch by Tolunay Orkun, 5 Mar 2004:wdenk
Fix early board initialization for Cogent CSB272 board * Patch by Ed Okerson, 3 Mar 2004: fix CFI flash writes for little endian systems * Patch by Reinhard Meyer, 01 Mar 2004: generalize USB and IDE support for MPC5200 with according changes to IceCube.h and TOP5200.h add Am29LV256 256 MBit FLASH support for TOP5200 boards add info about USB and IDE to README
2004-02-23* Patch by Peter Ryser, 20 Feb 2004:wdenk
Add support for the Xilinx ML300 platform * Patch by Stephan Linz, 17 Feb 2004: Fix watchdog support for NIOS * Patch by Josh Fryman, 16 Feb 2004: Fix byte-swapping for cfi_flash.c for different bus widths * Patch by Jon Diekema, 14 Jeb 2004: Remove duplicate "FPGA Support" notes from the README file
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-01-16[Strange. I _did_ check these in before. Seems SF restored an oldwdenk
version of the repository???] * Patch by Reinhard Meyer, 09 Jan 2004: - add RTC support for MPC5200 based boards (requires RTC_XTAL) * Add support for IDE LED on BMS2003 board (exclusive with status LED!) * Add support for PS/2 keyboard (used with PS/2 multiplexor on BMS2003 board) * Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004: Add common files for "emk" boards
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
