path: root/board/emk
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-28Patch by Reinhard Meyer, 28 Dec 2003:wdenk
Add initial support for TOP5200 board
2003-03-14* Avoid flicker on the TRAB's VFD by synchronizing the enable withwdenk
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100 boards, version 153 for Rev. 200 boards). * Patch by Vladimir Gurevich, 12 Mar 2003: Fix relocation problem of statically initialized string pointers in common/cmd_pci.c * Patch by Kai-Uwe Blöm, 12 Mar 2003: Cleanup & bug fixes for JFFS2 code: - the memory mangement was broken. It caused havoc on malloc by writing beyond the block boundaries. - the length calculation for files was wrong, sometimes resulting in short file reads. - data copying now optionally takes fragment version numbers into account, to avoid copying from older data. See doc/README.JFFS2 for details.
2003-03-06* Patch by Rune Torgersen, 13 Feb 2003:LABEL_2003_03_06_0200wdenk
Add support for Motorola MPC8266ADS board * Patch by Kyle Harris, 19 Feb 2003: patches for the Intel lubbock board: memsetup.S - general cleanup (based on Robert's csb226 code) flash.c - overhaul, actually works now lubbock.c - fix init funcs to return proper value * Patch by Kenneth Johansson, 26 Feb 2003: - Fixed off by one in RFTA calculation. - No need to abort when LDF is lower than we can program it's only minimum timing so clamp it to what we can do. - Takes function pointer to function for reading the spd_nvram. Usefull for faking data or hardcode a module without the nvram. - fix other user for above change - fix some comments. * Patches by Brian Waite, 26 Feb 2003: - fix port for evb64260 board - fix PCI for evb64260 board - fix PCI scan * Patch by Reinhard Meyer, 1 Mar 2003: Add support for EMK TOP860 Module * Patch by Yuli Barcohen, 02 Mar 2003: Add SPD EEPROM support for MPC8260ADS board
