path: root/board/embest
2019-01-01embestmx6boards: Add SPL supportFabien Lahoudere
In order to boot faster with falcon mode, we need to add SPL support to riotboard. Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2017-11-09board: imx6: marsboard: Remove doubled #include <asm/arch/sys_proto.h>Lukasz Majewski
The sys_proto.h file has been included earlier in this file. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-10-12imx: Include <input.h> header fileDiego Dorta
When building with W=1 errors like the one below is seen: board/freescale/mx6sabresd/mx6sabresd.c:546:5: warning: no previous prototype for ‘overwrite_console’ [-Wmissing-prototypes] int overwrite_console(void) Fix the build warnings by including <input.h>. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric Bénard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-11-24mx6boards: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Eric Benard <eric@eukrea.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-21ARM: i.MX: provide declaration for board_spi_cs_gpioEric Nelson
Provide a public declaration of the board_spi_cs_gpio() callback for i.MX SPI chip selects to prevent the warning "Should it be static?" when compiling with "make C=1". Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-09-24spi: mxc: fix sf probe when using mxc_spiNikita Kiryanov
MXC SPI driver has a feature whereas a GPIO line can be used to force CS high across multiple transactions. This is set up by embedding the GPIO information in the CS value: cs = (cs | gpio << 8) This merge of cs and gpio data into one value breaks the sf probe command: if the use of gpio is required, invoking "sf probe <cs>" will not work, because the CS argument doesn't have the GPIO information in it. Instead, the user must use "sf probe <cs | gpio << 8>". For example, if bank 2 gpio 30 is used to force cs high on cs 0, bus 0, then instead of typing "sf probe 0" the user now must type "sf probe 15872". This is inconsistent with the description of the sf probe command, and forces the user to be aware of implementaiton details. Fix this by introducing a new board function: board_spi_cs_gpio(), which will accept a naked CS value, and provide the driver with the relevant GPIO, if one is necessary. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Eric Benard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-08-13embest/mx6boards: only toggle eMMC usdhc3 RST line on MarSboardIain Paton
On MarS usdhc3 is eMMC, on RIoT usdhc3 is uSD and eMMC is usdhc4. Don't run the MarS specific eMMC reset code on usdhc3 when board_type == BOARD_IS_RIOTBOARD Signed-off-by: Iain Paton <ipaton0@gmail.com>
2014-04-15embest/mx6boards: use common detect_hdmiEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2014-04-15RiOTboard and MarSBoard: add new boards supportEric Benard
RiOTboard is produced by Embest/Element 14 and is based on i.MX6 Solo The following features are tested : - UART2 (console) - eMMC - SDCard - uSDCard - Ethernet - USB Host (through 4 ports hub) - HDMI output - I2C 1/2/3 - LVDS TFT with LCD8000-97C from Embest/Element 14 Boot on eMMC and through USB loader are tested. For more informations on this board : http://www.riotboard.org/ MarSBoard is produced by Embest/Element 14 and is based on i.MX6 Dual The following features are tested : - UART2 (console) - eMMC - uSDCard - Ethernet - USB Host (through 2 ports hub) - HDMI output - I2C 1/2 - SPI NOR Flash - LVDS TFT with LCD8000-97C from Embest/Element 14 Boot on SPI NOR and through USB loader are tested. For more informations on this board : http://www.embest-tech.com/shop/star/marsboard.html Both boards are supported by the same code base as they are based on a common trunk of schematics. Signed-off-by: Eric Bénard <eric@eukrea.com> Acked-by: Stefano Babic <sbabic@denx.de>
