path: root/board/eltec/mhpc/flash.c
2014-10-27ppc: Zap MHPC boardMarek Vasut
This board uses eeprom accessors in an incorrect way. The board is old and unsupported, just zap it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de>
2011-11-07board/eltec/mhpc/flash.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: flash.c: In function 'write_buff': flash.c:314:6: warning: variable 'count' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de>
