2008-10-21 | Cleanup: fix "MHz" spelling | Wolfgang Denk | |
Signed-off-by: Wolfgang Denk <wd@denx.de> | |||
2008-10-18 | rename CFG_ macros to CONFIG_SYS | Jean-Christophe PLAGNIOL-VILLARD | |
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> | |||
2005-10-13 | Cleanup for GCC-4.x | Wolfgang Denk | |
2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2002-09-17 | Initial revision | wdenk | |
