path: root/board/elgin
2020-03-26elgin-rv1108: Use rk_board_late_init() for GPIO settingsOtavio Salvador
Since commit 8e9a8d0d0c8c ("rockchip: elgin-rv1108: use board_early_init_f for per-boar init") the function that configure the board GPIOs is no longer called since CONFIG_BOARD_EARLY_INIT_F=y is not selected. These GPIOs do not need to be configured in such early stagem, so change it to rk_board_late_init() and also select CONFIG_BOARD_LATE_INIT=y to fix the regression. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-03-26rockchip: elgin-rv1108: Use syscon API to get grf baseKever Yang
Use syscon API to get grf base instead of get from dts. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2019-07-29rockchip: rv1108: Migrate to use common board fileKever Yang
Use common board file for board_init() and board_late_init(), for Rockchip SoCs have very similar process. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-29rockchip: elgin-rv1108: use board_early_init_f for per-boar initKever Yang
Use board_early_init_f() for per-board init operation and use board_init() from common board file. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-01rockchip: use 'arch-rockchip' as header file pathKever Yang
Rockchip use 'arch-rockchip' instead of arch-$(SOC) as common header file path, so that we can get the correct path directly. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-16ARM: rockchip: Add rv1108-elgin-r1 board supportOtavio Salvador
Add the initial support for Elgin R1 board, which is based on the RV1108 SoC and has the following features currently supported in U-Boot: - UART - eMMC - USB Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
