Perform a simple rename of CONFIG_PHY_ID to CFG_PHY_ID
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM
namespace do not easily transition to Kconfig. In many cases they likely
should come from the device tree instead. Move these out of CONFIG
namespace and in to CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NAND
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
These functions relate to memory init so move them into the init
header.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Add the dts files to support deivce tree, update the configuration
files to support the device tree and driver model. The peripheral
clock and pins configuration are handled by the clock and the pinctrl
drivers respectively.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
Due to introducing the new peripheral clock handle functions,
use these functions to reduce duplicated code.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Tested-by: Heiko Schocher <hs@denx.de>
[Rebased on current master, fixup for at91rm9200ek]
This value is not used by the network stack and is available in the
global data, so stop passing it around. For the one legacy function
that still expects it (init op on old Ethernet drivers) pass in the
global pointer version directly to avoid changing that interface.
Reported-by: Simon Glass <sjg@chromium.org>
(Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
The board select menu in arch/arm/Kconfig is still big.
To slim down it, this commit moves AT91 boards to
arch/arm/mach-at91/Kconfig.
Also, consolidate "config SYS_SOC" in each board Kconfig.
The Kconfig files under board/ directory were modified with the
following command:
find board -name Kconfig | xargs sed -i -e '
/config SYS_SOC/ {
N
/default "at91"/ {
N
d
Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de>
Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de>
Acked-by: Scott Wood <scottwood@freescale.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
commit 72fa467988e7944407a634ddc4bc6a2df685c04c moved atmel_mci_init() into
include/atmel_mci.h. Some AT91 boards are also using this interface and need
to include atmel_mci.h now.
This patch fixes MAKEALL complaints like this:
---8<---
Configuring for ethernut5 - Board: ethernut5, Options: AT91SAM9XE
ethernut5.c: In function 'board_mmc_init':
ethernut5.c:235:2: warning: implicit declaration of function 'atmel_mci_init' [-Wimplicit-function-declaration]
--->8---
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
CC: Albert Aribaud <albert.u.boot@aribaud.net>
CC: Reinhard Meyer <u-boot@emk-elektronik.de>
CC: egnite GmbH <info@egnite.de>
Fix build error for ethernut5 board due to prototype change
for function board_mmc_getcd().
ethernut5.c:238: error: conflicting types for 'board_mmc_getcd'
u-boot/include/mmc.h:318: note: previous declaration of 'board_mmc_getcd'
was here
make[2]: *** [ethernut5.o] Error 1
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tim Schendekehl <tim.schendekehl@egnite.de>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
Cc: egnite GmbH <info@egnite.de>
Add support for the Ethernut 5 open hardware design, based
on Atmel's AT91SAM9XE512 SoC.
V4
- Fix several coding style issues.
- Move machine type to config file.
- Remove use of CONFIG_ATMEL_LEGACY.
Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
