path: root/board/egnite
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2012-03-28atmel-boards: add missing atmel_mci.hAndreas Bießmann
commit 72fa467988e7944407a634ddc4bc6a2df685c04c moved atmel_mci_init() into include/atmel_mci.h. Some AT91 boards are also using this interface and need to include atmel_mci.h now. This patch fixes MAKEALL complaints like this: ---8<--- Configuring for ethernut5 - Board: ethernut5, Options: AT91SAM9XE ethernut5.c: In function 'board_mmc_init': ethernut5.c:235:2: warning: implicit declaration of function 'atmel_mci_init' [-Wimplicit-function-declaration] --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> CC: Albert Aribaud <albert.u.boot@aribaud.net> CC: Reinhard Meyer <u-boot@emk-elektronik.de> CC: egnite GmbH <info@egnite.de>
2012-02-29Ethernut 5: fix build errorprabhakar.csengg@gmail.com
Fix build error for ethernut5 board due to prototype change for function board_mmc_getcd(). ethernut5.c:238: error: conflicting types for 'board_mmc_getcd' u-boot/include/mmc.h:318: note: previous declaration of 'board_mmc_getcd' was here make[2]: *** [ethernut5.o] Error 1 Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tim Schendekehl <tim.schendekehl@egnite.de> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: egnite GmbH <info@egnite.de>
2011-12-06Ethernut 5 board supportTim Schendekehl
Add support for the Ethernut 5 open hardware design, based on Atmel's AT91SAM9XE512 SoC. V4 - Fix several coding style issues. - Move machine type to config file. - Remove use of CONFIG_ATMEL_LEGACY. Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
