path: root/board/egnite/ethernut5
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2012-03-28atmel-boards: add missing atmel_mci.hAndreas Bießmann
commit 72fa467988e7944407a634ddc4bc6a2df685c04c moved atmel_mci_init() into include/atmel_mci.h. Some AT91 boards are also using this interface and need to include atmel_mci.h now. This patch fixes MAKEALL complaints like this: ---8<--- Configuring for ethernut5 - Board: ethernut5, Options: AT91SAM9XE ethernut5.c: In function 'board_mmc_init': ethernut5.c:235:2: warning: implicit declaration of function 'atmel_mci_init' [-Wimplicit-function-declaration] --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> CC: Albert Aribaud <albert.u.boot@aribaud.net> CC: Reinhard Meyer <u-boot@emk-elektronik.de> CC: egnite GmbH <info@egnite.de>
2012-02-29Ethernut 5: fix build errorprabhakar.csengg@gmail.com
Fix build error for ethernut5 board due to prototype change for function board_mmc_getcd(). ethernut5.c:238: error: conflicting types for 'board_mmc_getcd' u-boot/include/mmc.h:318: note: previous declaration of 'board_mmc_getcd' was here make[2]: *** [ethernut5.o] Error 1 Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tim Schendekehl <tim.schendekehl@egnite.de> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: egnite GmbH <info@egnite.de>
2011-12-06Ethernut 5 board supportTim Schendekehl
Add support for the Ethernut 5 open hardware design, based on Atmel's AT91SAM9XE512 SoC. V4 - Fix several coding style issues. - Move machine type to config file. - Remove use of CONFIG_ATMEL_LEGACY. Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
