path: root/board/efi
2018-06-24x86: efi-x86_payload: Enumerate PCI bus during early bootBin Meng
The generic efi payload currently does not enumerate the PCI bus, which means peripherals on the PCI bus are not discovered by their drivers. This uses board_early_init_r() to do the PCI enumeration. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-24x86: efi-x86_app: Update MAINTAINERSBin Meng
Previous rename of efi-x86 target missed the MAINTAINERS update, which caused the buildman warnings: WARNING: no status info for 'efi-x86_app' WARNING: no maintainers for 'efi-x86_app' This updates the board MAINTAINERS to reflect the up-to-date info. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17x86: Rename efi-x86 target to efi-x86_appBin Meng
To avoid confusion, let's rename the efi-x86 target to efi-x86_app. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17x86: efi: payload: Add EFI framebuffer driver supportBin Meng
This turns on the EFI framebuffer driver support so that a graphics console can be of additional help. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17x86: Add generic EFI payload supportBin Meng
It is possible to create a generic EFI payload for all x86 boards. The payload is configured to include as many generic drivers as possible. All stuff that touches low-level initialization are not allowed as such is the EFI BIOS's responsibility. Platform specific drivers (like gpio, spi, etc) are not included. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select ARCH_EARLY_INIT_R in the platform KconfigBin Meng
This is architecture-dependent early initialization hence should be put in the platform Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-17x86: Drop all the old pin configuration codeSimon Glass
We don't need this anymore - we can use device tree and the new pinconfig driver instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: Add EFI board codeBen Stoltz
Add support for the efi-x86 board, which supports running U-Boot as an EFI 32-bit application. Signed-off-by: Ben Stoltz <stoltz@google.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
