path: root/board/ebv/socrates
2015-12-20arm: socfpga: Drop the board boilerplateMarek Vasut
Drop all the common board code, since it is not completely useless. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: socrates: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-20arm: socfpga: socrates: Remove Micrel PHY configurationMarek Vasut
The Micrel PHY configuration is now done from OF, so hard-coding the configuration into the board file is no longer necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-17usb: s3c-otg: Rename usb/s3c_udc.h to usb/dwc2_udc.hMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch renames the global s3c_udc.h header to dwc2_udc.h. The rename is done automatically: $ sed -i "s/s3c_udc\.h/dwc2_udc.h/g" \ `git grep "s3c_udc\.h" | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename s3c_udc_probe() functionMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the second and final to rename global symbol, the s3c_udc_probe() function. The rename is done automatically: $ sed -i "s/s3c_udc_probe/dwc2_udc_probe/g" \ `git grep s3c_udc_probe | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename struct s3c_plat_otg_dataMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the first to rename global symbol, the struct s3c_plat_otg_data. The rename is done automatically: $ sed -i "s/s3c_plat_otg_data/dwc2_plat_otg_data/g" \ `git grep s3c_plat_otg_data | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-11-30arm: socfpga: Repair SoCrates boardMarek Vasut
This board was constantly parasiting on the CV SoCDK, so split it into it's own separate directory. Moreover, the board config was missing important bits, like simple-bus support in SPL, the DRAM configuration was incorrect and the DTS was also missing the pre reloc bits. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Jan Viktorin <viktorin@rehivetech.com>
