Prefix mmu.h PAGE_xxx definitions with MMU_ in order to prevent a naming
conflict with other definitions.
[trini: Fixup common/cmd_io.c]
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
Use the MMU hardware to set up 1:1 mappings between physical and virtual
addresses. This allows us to bypass the cache when accessing the flash
without having to do any physical-to-virtual address mapping in the CFI
driver.
The virtual memory mappings are defined at compile time through a sorted
array of virtual memory range objects. When a TLB miss exception
happens, the exception handler does a binary search through the array
until it finds a matching entry and loads it into the TLB. The u-boot
image itself is covered by a fixed TLB entry which is never replaced.
This makes the 'saveenv' command work again on ATNGW100 and other boards
using the CFI driver, hopefully without breaking any rules.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
The paging system which is required to set up caching properties has not
yet been initialized when the SDRAM is initialized. So when the
map_physmem() function is converted to return the physical address
unchanged, the SDRAM initialization will break on some boards.
The avr32-specific uncached() macro will return an address which will
always cause uncached accessed to be made. Since this happens in the
board code, using avr32-specific features should be ok, and will allow
the SDRAM initialization to keep working.
board/atmel/atngw100/atngw100.c
board/atmel/atstk1000/atstk1000.c
cpu/at32ap/at32ap700x/gpio.c
include/asm-avr32/arch-at32ap700x/clk.h
include/configs/atngw100.h
include/configs/atstk1002.h
include/configs/atstk1003.h
include/configs/atstk1004.h
include/configs/atstk1006.h
include/configs/favr-32-ezkit.h
include/configs/hammerhead.h
include/configs/mimc200.h
This addresses all drivers whose initializers have already
been moved to board_eth_init()/cpu_eth_init().
Replace the avr32-specific board_init_info hook by the standard
board_early_init_r hook and make it optional.
board_early_init_r() runs somewhat earlier than board_init_info used to
do, but this isn't a problem for any of the in-tree boards.
- Separate the portmux configuration functionality from the GPIO pin
control API.
- Separate the controller-specific code from the chip-specific code.
- Allow "ganged" port configuration (multiple pins at once).
- Add more flexibility to the "canned" peripheral select functions:
- Allow using more than 23 address bits, more chip selects, as
well as NAND- and CF-specific pins.
- Make the MACB SPEED pin optional, and choose between MII/RMII
using a parameter instead of an #ifdef.
- Make it possible to use other MMC slots than slot 0, and support
different MMC/SDCard data bus widths.
- Use more reasonable pull-up defaults; floating pins may consume a
lot of power.
- Get rid of some custom portmux code from the mimc200 board code. The
old gpio/portmux API couldn't really handle its requirements, but
the new one can.
- Add documentation.
The end result is slightly smaller code for all boards. Which isn't
really the point, but at least it isn't any larger.
This has been verified on ATSTK1002 and ATNGW100. I'd appreciate if
the board maintainers could help me test this on their boards. In
particular, the mimc200 port has lost a lot of code, so I'm hoping Mark
can help me out.
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Mark Jackson <mpfj@mimc.co.uk>
Cc: Alex Raimondi <alex.raimondi@miromico.ch>
Cc: Julien May <julien.may@miromico.ch>
Changes since v1:
* Enable pullup on NWAIT
* Add missing include to portmux-pio.h
* Rename CONFIG_PIO2 -> CONFIG_PORTMUX_PIO to match docs
This patch adds support for the Favr-32 board made by EarthLCD.
This kit, which is also called ezLCD-101 when running with EarthLCD firmware,
has a 10.4" touch screen LCD panel, 16 MB 32-bit SDRAM, 8 MB parallel flash,
Ethernet, audio out, USB device, SD-card slot, USART and various other
connectors for cennecting stuff to SPI, I2C, GPIO, etc.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
