path: root/board/eXalion
2007-07-04Remove obsolete mpc824x linker scripts (1 of 4)Grant Likely
2004-03-25Code cleanupLABEL_2004_03_25_1630wdenk
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
