path: root/board/eXalion
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-04Remove obsolete mpc824x linker scripts (1 of 4)Grant Likely
2004-03-25Code cleanupLABEL_2004_03_25_1630wdenk
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
